David Edis Posted January 1, 2023 Posted January 1, 2023 Yellow warning light come on. Auto lock no longer works. Use fob and all doors apart from drivers door locks. Battery in fob new. Driver’s mirror also doesn’t fold in. Any help appreciated
Steve Q Posted January 1, 2023 Posted January 1, 2023 I'd recommend a diagnostic check to see if any fault codes flag up. Could be an issue with the drivers door lock module.
Magnet Posted January 2, 2023 Posted January 2, 2023 Hello David, Worth checking within the flexible harness section between the door and the body A post. It’s not uncommon for wires to fracture within this section due to regular opening and closing of the door - particular in cold weather when the harness becomes more brittle. Kind regards, Gareth.
