A6-Maint Posted January 9, 2023 Posted January 9, 2023 (edited) Newbie question: I have a 2010 A6 C6 Le-Mans on which drivers door won't lock from the key fob but can dead lock physically with the key. All other doors operate as normal. In addition, on the same door I have no response from the mirror adjustment button on either mirror and the indicator repeater does not drive the indicator. Passenger side is all OK. Windows operate fine too. Are all these issues connected to one module or do I have multiple issues? i.e do I have separate door actuator and door control module problems? All suggestions welcome. Also, if I do need to change the actuator is it a window regulator out job? Thanks. Edited January 9, 2023 by A6-Maint
Steve Q Posted January 13, 2023 Posted January 13, 2023 I'd recommend an auto electrican to take a look at the wiring for any breaks or corrosion. Alternatively I'd recommend a diagnostic check to see if any fault codes flag up. It could be the drivers door lock module but this should come up on a diagnostic check
Alfie6 Posted October 16, 2024 Posted October 16, 2024 On 1/9/2023 at 9:09 PM, A6-Maint said: Newbie question: I have a 2010 A6 C6 Le-Mans on which drivers door won't lock from the key fob but can dead lock physically with the key. All other doors operate as normal. In addition, on the same door I have no response from the mirror adjustment button on either mirror and the indicator repeater does not drive the indicator. Passenger side is all OK. Windows operate fine too. Are all these issues connected to one module or do I have multiple issues? i.e do I have separate door actuator and door control module problems? All suggestions welcome. Also, if I do need to change the actuator is it a window regulator out job? Thanks. Expand
Alfie6 Posted October 16, 2024 Posted October 16, 2024 My fob will not now open my drivers door. Its happen now and again over the last six months but now it will not work at all. I have checked all other functions are working fine and new battery. Just wondering did you fix yours and how ? cheers
