Zk2007 Posted January 14, 2023 Share Posted January 14, 2023 Hi I have an a3 where the gearbox is playing up usually when I'm slowing down from 12mph downwards the gear change is not smooth. All other times it's fine. The problem started off just once in a while and is now becoming more frequent. I wanted to know can anyone recommend any places that deal with the gearbox around Coventry or West Midlands area?Thank you Quote Link to comment Share on other sites More sharing options...
Magnet Posted January 14, 2023 Share Posted January 14, 2023 Hello Zahir, Usually worth a gearbox oil change first. Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted January 15, 2023 Share Posted January 15, 2023 I agree with Gareth, definitely do the gearbox oil change if not done in a while. You could also look to see if the gearbox software needs updating or a diagnostic check.ro see if any fault codes flag up. There's an independent Audi specialist in Wigston Leicester called Chapman's. I've never used them but they could be one of the closer Audi specialists to you. Quote Link to comment Share on other sites More sharing options...
Zk2007 Posted January 15, 2023 Author Share Posted January 15, 2023 Thanks guys the dsg service was done at approximately 80k it's now on 105k. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted January 15, 2023 Share Posted January 15, 2023 2 hours ago, Zk2007 said: Thanks guys the dsg service was done at approximately 80k it's now on 105k. Hmm so in theory it should be ok and not need a service Quote Link to comment Share on other sites More sharing options...
