FM8193 Posted January 17, 2023 Posted January 17, 2023 Hi Am having an issue with my Audi A6 it’s 2.0 2014 tdi manual recently car is not starting sometimes and sometimes it would start so I had it scanned and the mechanic said it was master clutch cylinder that had the switch built into these models so I would need replacement so I had it replaced and now the issue has gotten worse now car doesn’t start at all with button if I let it roll down hill and do a jump start it works I was really hoping if anyone could give me a advice or have experienced anything like this it would be much appreciated thanks
Steve Q Posted January 17, 2023 Posted January 17, 2023 I'd be taking this back to the garage that did the work as it sounds like it's been misdiagnosed. Could it be a starter motor?
evopilot Posted January 22, 2023 Posted January 22, 2023 wouldn't say that's the master cylinder at all going by being able to start on a rolling start two questions? 1. Have you any fault codes with VCDS or ODIS (or any reputable diagnostics scanner) 2. Next time you go to first start the car in the morning can you attach a jumper pack or jump leads and try a cold start to see if the problem remains? I ask the above as question 1 would tell you if you had a master cylinder sensor fault or a starter motor circuit fault and question 2 is more of a hunch.... Ive seen on 2 Audi's now when the battery is getting tired everything looks OK but theirs not enough kick in the battery to start her when shes cold especially with the cold snap of December/January weather
FM8193 Posted January 31, 2023 Author Posted January 31, 2023 I went to another mechanic he did his scans and was able to remove the no engine start fault code however now it’s keep saying press clutch to start the car although there is a new master cylinder and he can see on the scanner there are reads when you press the clutch and release it he went under the car and was able to start the car directly from there and same with the fuse box next to the master cylinder so the relay is getting the signal from the car when I press the button because I can hear the click but it’s unable to send the signal to main ecu or the back ecu so there are two ecu in car but when he connects his text wire he is able to start the car through relay any way he spend good two days trying to find which cable it was most likely a damaged or broken cable he installed a new switch through the front relay so I am able to start the car without having to press the clutch it’s good short term solution as I am able to use the car for the time being but I would want to get it fixed in case I want to sell the car also not sure how the MOT gonna go if they be able to pass it with a separate start switch
Steve Q Posted January 31, 2023 Posted January 31, 2023 At least you've got a temporary fix. Sounds like your mechanic is very knowledgeable 👍
superscub11 Posted December 27, 2023 Posted December 27, 2023 Did you ever find out the issue. Have the same problem
Magnet Posted August 2, 2024 Posted August 2, 2024 Hello Salim, Neither of the posters have been on here for some time. I suggest you send them a PM. Many thanks.
