ted cummins Posted January 22, 2023 Posted January 22, 2023 my 2014 q5 sline 2.0 tdi rear hatch had occasional lift and close problems it does lock/unlock but now it will not lift at all. pushing it open by hand is a pain and cant be doing the struts any good my wife is wheelchair bound so i keep the wheel chair in the boot all the time could this in anyway affect the open and close.
Steve Q Posted January 22, 2023 Posted January 22, 2023 38 minutes ago, ted cummins said: my 2014 q5 sline 2.0 tdi rear hatch had occasional lift and close problems it does lock/unlock but now it will not lift at all. pushing it open by hand is a pain and cant be doing the struts any good my wife is wheelchair bound so i keep the wheel chair in the boot all the time could this in anyway affect the open and close. I'd recommend a diagnostic check to see if any fault codes flag up. It could be the lift motor.
ted cummins Posted February 4, 2023 Author Posted February 4, 2023 On 1/22/2023 at 2:12 PM, Steve Q said: I'd recommend a diagnostic check to see if any fault codes flag up. It could be the lift motor. i thought i would try the tailgate today using the fob, lo and behold it opened and lifted to the fully open position, first time in months ( but it would not shut), so at least i know the lift motor works. A bit of extra info, the car has stood for a very long time and not used much by previous owner, its a 2014 model with only 15000 on the clock. i have bought a diagnostic tester but as yet have not located the 16 pin socket its above the pedals ( i am told) will use a mirror tomorrow . Thanks for the suggestion Steve
Steve Q Posted February 5, 2023 Posted February 5, 2023 You're welcome. The socket will be hidden under the dash and may have a cover protecting it.
