Sonny1 Posted January 23, 2023 Posted January 23, 2023 Hello everyone. my beautiful 98 cabriolet is having some roof problems. Wondering if anyone has had any experience/ can offer some advice. thank you all. sonny
Turlough Posted January 23, 2023 Posted January 23, 2023 1 hour ago, Sonny1 said: Hello everyone. my beautiful 98 cabriolet is having some roof problems. Wondering if anyone has had any experience/ can offer some advice. thank you all. sonny Hi Sonny1 would you like to say what the problems are. 1
Sonny1 Posted January 23, 2023 Author Posted January 23, 2023 Hi. Car broke down with a failed alternator with the roof down, and it had to be closed manually. After the alternator problems and new battery were installed, the roof will not go down the windows will go down slightly as normal when you twist the latch but the roof will not move when you press the button to unfold it. thanks
Turlough Posted January 23, 2023 Posted January 23, 2023 Hi Sonny1 I am no expert on Cabriolet electric roofs but when I have had similar problems I usually keep trying different things and usually get the problem resolved. I would try to reset the roof by putting the roof down manually making sure the boot lid and the roof compartment cover are closed properly, turn the ignition off then on and try raising the roof electrically. Micro switches on the boot lid and the roof compartment cover latches play a big part in the smooth operation of the roof. hope this works for you! Turlough. 2
Sonny1 Posted January 23, 2023 Author Posted January 23, 2023 4 hours ago, Turlough said: Hi Sonny1 I am no expert on Cabriolet electric roofs but when I have had similar problems I usually keep trying different things and usually get the problem resolved. I would try to reset the roof by putting the roof down manually making sure the boot lid and the roof compartment cover are closed properly, turn the ignition off then on and try raising the roof electrically. Micro switches on the boot lid and the roof compartment cover latches play a big part in the smooth operation of the roof. hope this works for you! Turlough. Thank you very much for your advice. 👍
Sonny1 Posted January 24, 2023 Author Posted January 24, 2023 17 hours ago, Sonny1 said: Thank you very much for your advice. 👍 Turlough that worked! Reset the roof back to fully open position then the normal switch to close it began functioning again. Full open/close function now restored. you’re a legend! Thanks again for your help. S 2
Turlough Posted January 24, 2023 Posted January 24, 2023 You’re very welcome thanks for coming back to let me know! T 2
