mlj76 Posted January 25, 2023 Posted January 25, 2023 So usually when not accelerating, there is a weird intermittent sort of rubbing sound from drivers side down by wheel, kinds of sound like something spinning and rubbing its like cha cha cha cha (excuse the cha cha Chas don’t know how to explain it lol) does not always do it and it lasts for about 10 seconds so don’t even have time to brake test, pressing clutch does nothing to stop it also have abs/traction control light on every now and then, and just as I was driving in the wet the wheel on the driver side seemed to jump a little ive had a look underneath and nothing seems loose or broken!! Any ideas!!! Audi a4 b6 avant diesel 1.9t
Steve Q Posted January 28, 2023 Posted January 28, 2023 Could be caused by a seized piston in the brake caliper causing the brake pad to be rubbing on the brake disc when brakes aren't applied. Definitely worth getting this checked out.
mlj76 Posted January 31, 2023 Author Posted January 31, 2023 Yep brake pads where shot, good clean of callipers and new pads seem to have fixed the issue strange though as the side making the sound were In slightly better condition 🤷🏻♂️ i did find that someone had cut off the wear indicator wire on the worst side!! And stuck a bit of wire in plug. And now I’ve re connected the new pads I’ve got a brake service light on so guessing past owner had an issue with this 🤦
Steve Q Posted January 31, 2023 Posted January 31, 2023 Sounds like the previous owner did a bodge job! Glad you got sorted.
mlj76 Posted January 31, 2023 Author Posted January 31, 2023 After seeing them I think both callipers could do with a rebuild, think the one that was making noise is sticking a little bit, not as much after I’ve cleaned them but I fear it will again
Steve Q Posted February 2, 2023 Posted February 2, 2023 On 1/31/2023 at 10:02 PM, mlj76 said: After seeing them I think both callipers could do with a rebuild, think the one that was making noise is sticking a little bit, not as much after I’ve cleaned them but I fear it will again Most likely
