diesel1964 Posted January 27, 2023 Share Posted January 27, 2023 Quote Link to comment Share on other sites More sharing options...
Steve Q Posted January 27, 2023 Share Posted January 27, 2023 Hi Andrew please could you give us more information? Power loss could be caused by various reasons such as failing turbos, injectors or maf sensors etc. Quote Link to comment Share on other sites More sharing options...
diesel1964 Posted January 28, 2023 Author Share Posted January 28, 2023 When it reaches about 3000rpm if I put my foot down to go faster then the gear's start changing back down ànd I go slow down Quote Link to comment Share on other sites More sharing options...
diesel1964 Posted January 28, 2023 Author Share Posted January 28, 2023 Could it be something to do with multitronic software needs update Quote Link to comment Share on other sites More sharing options...
Steve Q Posted January 28, 2023 Share Posted January 28, 2023 Id recommend a diagnostic check to see if any fault codes flag up. When was the gearbox oil.last changed as this can affect the gearbox changing gears. Yea you could try a software update on the gearbox or needing a new sensor. Worst case scenario it's the module that may have failed. Quote Link to comment Share on other sites More sharing options...
diesel1964 Posted January 29, 2023 Author Share Posted January 29, 2023 Thanks guys will do Quote Link to comment Share on other sites More sharing options...
