kh904 Posted January 31, 2023 Posted January 31, 2023 Hi all, I've had a warning message pop up on my 2018 sportback (b9) - 'Right rear brake light defective'. I've had a look at the rear and the rear light works when I put the lights on, the indicator works, but the brake light doesn't when I press the brake pedal. Does anyone have any idea how to replace the brake light led? I've had a look online and can't seem to find any info! There seems to be a bit of condensation/moisture in the housing (passenger side seems fine and works ok). Thanks in advance
kh904 Posted January 31, 2023 Author Posted January 31, 2023 Ok, so i've used my obdeleven scanner and done numerous output checks and itried the followi g: All rear lights - all the lights except the right rear brake light were on All left rear lights - all left rear lights were on and ok All right rear lights - all right rear lights except the right rear brake light were on All brake lights - ALL the brake lights were on INCLUDING the right rear brake light! So the LEDs on the right brake lights are not blown which make me confused on how that can be! The fault code on the scanner is: B12C313 (Rear brake light bulb - open circuit), status: static and U112100 (Databus missing message), status: intermittent Not sure if that helps anyone?!
kh904 Posted February 4, 2023 Author Posted February 4, 2023 Ok, just an update for those who may have a similar problem.... I removed the rear light cluster and thought that I could open up the unit, but unfortunately not. It's a sealed unit, so you can't easily replace the leds, so I purchased a replacement cluster and so far the problem is fixed. It seems that enough moisture go into the clutter to cause the fail. It does seem that it's bad product design from Audi, especially the water channels where the tailgate/boot meets the taillight cluster. The rubber & plastic trim isn't water tight and water can get through! 2
corinohara11119 Posted September 13, 2024 Posted September 13, 2024 I have the same thing do u need to buy a new rear light or is it something else
kh904 Posted September 14, 2024 Author Posted September 14, 2024 Unfortunately the unit will need to be replaced. You maybe able to get a specialist to recondition it but I would guess that it won't be much cheaper than buying a replacement cluster. It's dead simple to replace (youtube is helpful), but be careful as the are many variations/different part numbers and there are different styles over the years. There is also the standard colour and there's a darker tinted colour, so make sure you get one that matches your current cluster 1
