This has popped up, Amber P with red line strike through. Console brake button activates red in normal operation.
how reliable is that sensor? Over sensitive/false alarm?
thanks
marty
I'd recommend a diagnostic check to see if any fault codes flag up. It'll give you peace of mind at the very least
Will do and will clear the Ecs one again, to see if the cataclean improves the sensitivity of sensor. If ECS returns may have to replace sensor bank 3 was the last report.
