Conorc1983 Posted February 26, 2023 Share Posted February 26, 2023 Good afternoon all! I’m wondering can i ask your advice. I bought an a6 c6 3.0 TDI Quattro for a bargain. The only fly in the ointment is that the radio, screen and button are all completely dead. I’ve checked some fuses (but not entirely sure which ones to check - I’ve checked a 30a fuse in the boot and replaced just in case it was bad.) when I took out the left hand boot liner I saw this which I see is the amp and the other parts I’m not sure. When I disassembled this, I was greeted with this so I’m wondering if anyone can advise on what else I should check. And also if these other random boxes are actually needed. I also got a vcds scan done which I’ll attach too! Any help would be greatly appreciated! Log-TESTA6POST-WAUZZZ4F86N138801-380650km-236524mi.txt Quote Link to comment Share on other sites More sharing options...
Steve Q Posted February 26, 2023 Share Posted February 26, 2023 I'd recommend a diagnostic check to see if any fault codes flag up. Alternatively get an Audi specialist or auto electrican to take a look 1 Quote Link to comment Share on other sites More sharing options...
Conorc1983 Posted February 26, 2023 Author Share Posted February 26, 2023 Hi Steve. I have had it plugged into the vcds and it shows the following I’ve just ordered some of the fibre loopback connectors to start from there Quote Link to comment Share on other sites More sharing options...
Steve Q Posted March 1, 2023 Share Posted March 1, 2023 Might be worth ordering a second hand head unit but bare in mind it might need coding to the car 1 Quote Link to comment Share on other sites More sharing options...
Conorc1983 Posted March 1, 2023 Author Share Posted March 1, 2023 Another quick update folks. I was in the engine bay doing some servicing last night when I noticed the plenum drain completely blocked and a pool of water sat there stagnant. After I cleared that and cleared the drain, I thought some of the water may have seeped through the firewall to the components. when I removed the MMI / CD player in the glove box, the 10amp fuse in the back of the unit looked rusted. So I replaced it and plugged it back in and SUCCESS!!!! Everything powered back on!! So I’ve basically left a heater in there today to try and dry parts out. While it wasn’t saturated, it was a little damp. hopefully this helps someone! Quote Link to comment Share on other sites More sharing options...
Steve Q Posted March 2, 2023 Share Posted March 2, 2023 Wow thanks for the update. Audi's love to let water in that way. Quote Link to comment Share on other sites More sharing options...
