ceckogenchev Posted March 5, 2023 Posted March 5, 2023 I serviced the Audi A6 C7 3.0 245hp s-tronic gearbox as well as the valves and mechatronics installation. The mechanic advised me to go to WV and have them update the software on the box..... I did this update, but a few days ago when I put the lever on the R, an error came up in the box. I connected to VCDS and it showed error P284A00 S Tronic, 18051 - Shift fork 2. Has anyone had this problem and how did they solve it? Thanks in advance 18051 - Shift Fork 2 P284A 00 [096] - Stuck Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 40 Mileage: 243842 km Engine RPM: 804 /min Transmission input speed: 804 /min Transmission output speed: 0 /min Engine torque: 64 Nm ATF temperature: 62 °C Accelerator pedal position: 0.0 % Clutch status: Kupplung 2 kann Moment ьbertragen Unlearning counter according OBD: 40
ceckogenchev Posted April 19, 2023 Author Posted April 19, 2023 Apparently no one has faced such a problem. 😞
S5Bob Posted January 8, 2024 Posted January 8, 2024 Hello did you ever find a solution to this I have the exact same error code on my b8.5 s5
ceckogenchev Posted January 8, 2024 Author Posted January 8, 2024 Not unfortunately, still looking for a solution.
