Posted (edited)
Hello
I have problems with my rear right door the window won’t work unless I take everything apart then put it back together then it works.
But then if I take the keys out of ignition and try again I’m back to square one with it not working again.
I have checked the harness in my drivers door which were frayed so repaired nothing seems to fix it.
Plugged the car into my Carista and I’m getting a code for rear door module so changed the window motor and having same problems
Any help would be appreciated thanks
Edited by Shaun8p
Spelling mistakes
2 hours ago, Shaun8p said:
Hello
Hi can you publish the code please, this is where VCDS or OBD Eleven score as they give the part number of the offending module, also have you tried a global reset on all windows with the key fob.
