cpjvej2016 Posted March 6, 2023 Posted March 6, 2023 Hi all I have recently picked up an A4 2005, previous owner changed battery in the key and since then remote buttons on the key havent worked. Sure enough, ive tried to program the key the manual ways (In the ignition, turn on, hold buttons) to no avail. Red light blinks on the key. I have VCDS and upon going into program the keyfob that way, VCDS will not allow me to use the drop down at the top - select Remote Key Fob Adaption. Key works in the doors and starts the car fine. Faulty CCM? Any advice greatly appreciated! Thanks!
cpjvej2016 Posted March 6, 2023 Author Posted March 6, 2023 37 minutes ago, Steve Q said: Have you done the key fob reset? Cant says I have Is that where you select Channel 0 and hit read/save?
Steve Q Posted March 6, 2023 Posted March 6, 2023 2 hours ago, cpjvej2016 said: Cant says I have Is that where you select Channel 0 and hit read/save? The video should advise how. If that doesn't work then it could be an issue with the CCM, signal receiver.
cpjvej2016 Posted March 7, 2023 Author Posted March 7, 2023 9 hours ago, Steve Q said: The video should advise how. If that doesn't work then it could be an issue with the CCM, signal receiver. Which video - the above 1 is 7 seconds long and is a Pizza ad. lol
cpjvej2016 Posted March 7, 2023 Author Posted March 7, 2023 (edited) 13 hours ago, Steve Q said: The video should advise how. If that doesn't work then it could be an issue with the CCM, signal receiver. OK something is going on. After I have clicked Save - its not saving the keyfob - the value goes back to 0. My Keyfob is not recognised at all but I did find one ion the car that is not from this car (off another Audi) which does say recognised - so my plan was to keep that with the working key and just sue it as a keyfob but Alas, VCDS does not seem to be storing the fob :(. Edited March 7, 2023 by cpjvej2016
cpjvej2016 Posted March 7, 2023 Author Posted March 7, 2023 Update - the 'other' key has randomly started working! Bonus.
zakaz Posted September 30, 2024 Posted September 30, 2024 (edited) it is standart problem with keys 2004-2006 year with key number 8E0837220K . You should to make new key with remote 8E0837220Q (2007-2008 years). About this problem you can read here https://ikey.by/izgotovlenie-chip-klyuchey/audi-izgotovlenie-chip-klyuchey/izgotovlenie-chip-klyucha-audi-a4/, you should programm only new original key with number 8E0837220Q. Edited September 30, 2024 by zakaz
