6 hours ago, cursor-delta0g said:
Check brake pads - MIL notification
Out of interest what is this notification level set at? 70% wear?
No it means you have about 20% left on the linings, beyond that the piston travel is likely to seize out.
Cheers, no indication whether they are front or rear, ? Need to be replaced in pairs, or does it makes sense whole set front and back? Costs?
Hi no visually check the pads, if the backing plate is about 4mm from the discs they are knackered, there are loads of options on eBay as long as they are marked E11/E9 they are O.E. standard, its worth paying the extra couple of quid for the ones that come with the wear sensor.
Well brake pads are being replaced, front and back. Discs are good and the pad indicator wasn’t over zealous. Good even wear throughout.  Sub £300. Obviously betters Audi but this local brakes and discs only garage  beat another local general garage. Every saving helps.
Marty
Just to add, regarding the brake pad warning light. It only applies to the front as the front only has the wear sensor.
5 hours ago, cursor-delta0g said:
Interesting, does that mean rear brake pad  sensors don’t exist or just not connected to MiL
I know on my A6 I only have fronts.
