Mario T Posted March 11, 2023 Posted March 11, 2023 Hi There, I've just bought a new xtron radio but before I change it could I check whether there is a radio code required from the original radio.? I know on my Skoda providing I fit the radio that came with the car there isn't.??? If there is code can I get this from VCDS before I swap it out.?.? Thankyou
Stevey Y Posted March 11, 2023 Posted March 11, 2023 2 hours ago, Mario T said: Hi There, I've just bought a new xtron radio but before I change it could I check whether there is a radio code required from the original radio.? I know on my Skoda providing I fit the radio that came with the car there isn't.??? If there is code can I get this from VCDS before I swap it out.?.? Thankyou Hi if its an aftermarket radio I don't think coding will be required as it works independently of the original system and has no affiliation with the BCM and probably has a can bus shunt in it so any cars system will accept it, but the code for the original will be on VCDS so just make a copy of it as plan B. Steve.
Mario T Posted April 7, 2023 Author Posted April 7, 2023 Thanks Steve is it easy to get the code form VCDS.?
