Raymond ring Posted March 21, 2023 Posted March 21, 2023 Sorry my description early was wrong it’s a intake valve
Stevey Y Posted March 21, 2023 Posted March 21, 2023 35 minutes ago, Raymond ring said: Sorry my description early was wrong it’s a intake valve Hi it was right on the first go its a throttle housing, as for the spacers I can't answer that one but if you can get the part number off of the unit you can probably buy another unit from eBay for sub £200, if you have a fair amount of milage on the car changing the unit will do it a world of favours, BTW did they trot out the same old information that diesels don't have a throttle valve, they do, otherwise they would never run. Steve.
Raymond ring Posted March 21, 2023 Author Posted March 21, 2023 Hi Steve , thanks for your answer but not the whole unit I want , in the picture the arm that comes down is attached to a insert on this insert there are two over washers it’s just these washes I need ,
Stevey Y Posted March 21, 2023 Posted March 21, 2023 10 minutes ago, Raymond ring said: Hi Steve , thanks for your answer but not the whole unit I want , in the picture the arm that comes down is attached to a insert on this insert there are two over washers it’s just these washes I need , Hi what I am trying to put across is yes I realise its the washers you want but the only thing you can do is contact the manufacturer of the body and ask them if they can supply the washers as a courtesy, failing that its a new unit, just a random question but why did you dismantle the unit in the first place. Steve.
Raymond ring Posted March 21, 2023 Author Posted March 21, 2023 Arm kept coming off, thanks for reply I will try manufactures.
