Spenno Posted March 21, 2023 Posted March 21, 2023 Hi All, I have recently purchased a 2018 Audi A5 2 door S Line Coupe, and the rear driver's side interior light (the strip just below the window, above the arm rest) isn't working. All other interior lights are fine, including the same one on the passenger side. I've searched all over, but can't find much info about what it could be. Has anyone come across the issue before and is it something as simple as just changing the LED strip? If so, is there any guidance anywhere on how to do this? Thanks in advance!
Sergiu Gahniuc Posted July 16, 2024 Posted July 16, 2024 On 3/21/2023 at 5:05 PM, Spenno said: Hi All, I have recently purchased a 2018 Audi A5 2 door S Line Coupe, and the rear driver's side interior light (the strip just below the window, above the arm rest) isn't working. All other interior lights are fine, including the same one on the passenger side. I've searched all over, but can't find much info about what it could be. Has anyone come across the issue before and is it something as simple as just changing the LED strip? If so, is there any guidance anywhere on how to do this? Thanks in advance! Hi, i know it is a long time since you posted the problem, i have the same issue but the lights for the whole door don t work and i don t know what to do. Did you managed to fix it ? Thanks
