Beany1 Posted March 21, 2023 Posted March 21, 2023 Hi have a a4 b7 2.0 tdi car cut out while driving now wont start it is cranking but wont start if anyone can help thanks
Steve Q Posted March 22, 2023 Posted March 22, 2023 I'd recommend a diagnostic check to see if any fault codes flag up
Beany1 Posted March 22, 2023 Author Posted March 22, 2023 Hi steve checked everything no code the fuel pump is working battery and alteenator fine thinkinking its the crankshaft sensor do you know where it is thanks
Stevey Y Posted March 22, 2023 Posted March 22, 2023 5 hours ago, Beany1 said: Hi steve checked everything no code the fuel pump is working battery and alteenator fine thinkinking its the crankshaft sensor do you know where it is thanks Hi the sensor will either be down by the crank pulley or at the back of the engine in its own recess where the g/box joins the engine about half way down on the r/h side looking at it from the front of the car. Steve. 1
Beany1 Posted March 22, 2023 Author Posted March 22, 2023 Thanks steve had a look at forum and few videos and it looks like its behind the oil filter housing on the right hand side like you said . I will take a few things apart tommorow and have a look thanks for help
Mpc Posted July 19, 2024 Posted July 19, 2024 Any solutions for this, it happened to mine last week, but isn’t the crankshaft sent thanks matt
