Upgrading to LED indicators when headlights are Xenon
RWB8
I am looking for some guidance on switching to LED front indicators when my 2010 B8  has factory fitted Xenon headlamps. Are they any tips or guides when fitting them e.g. do headlamps have to come out or similar problems? Or is it a case of just swapping the standard indicator bulbs for LEDs? Any advice appreciated. Thank you.
Hi you should be fine fitting LEDs as long as the bulb base is the same and they are Canbus error free versions.
