thatukguy_james Posted March 24, 2023 Posted March 24, 2023 Help it helps,聽 still trying to do a few myself and cant for the life of me get the dip on back up on my a1 to work 馃檪聽says i need pro聽 Quote MMI PLUS Hidden Menu Select Control unit 5F (infotainment) Adaptation Channel 06 New Value: 1 After coding, push the Car+Menu button in the same time. 聽 Quote MMI Basic Hidden Menu Select Control unit 56 (Radio) Adaptation Channel 05 New Value: 1 After coding, push the Car+Menu button in the same time. 聽 Quote Highway Lights Select Control unit 09 (Central Electrics) Control unit Long Coding Subsystem: Rain / Light Sensor (RLS) Byte 0 Enable Bit 0 聽 Quote CD Eject Button Activation Select Control unit 5F (Informationselektronik) Adaptation Select channel 10 1 -Eject Lock Active 0 - Eject Lock De-Active 聽 Quote Lower Passenger Mirror When Reverse Gear Select Control unit 52 (T眉relektr. Beifahr.) Control unit Long Coding Byte 04 Bit 2-Activate Bit 3-Activate Select Control unit 09 (Central Electrics) Control unit Long Coding Byte 04 Bit 3-Activate 聽 Quote Confort Blink Cycle Select Control unit 09 (Central Electrics) Security access Access Code : 20113 Adaptation Comfort Blink (Cycles) Value: 1-5 Value 3 (standard - 3x blinking) 聽 Quote Cornering Fog Light Activation Select Control unit 09 (Central Electrics) Control unit Long Coding Byte 14 Bit 7 Activate. 聽 Quote Comin Home/Leaving Home Light Duration Select Control unit 09 (Central Electrics) Adaptation Coming Home Time Value (Default: 15 seconds - maximum: 60 seconds) Select Control unit 09 (Central Electrics) Adaptation Leaving Home Time Value(Default: 60 seconds - maximum: 60 seconds) 聽 Quote Comin Home/Leaving Home with Fog and LED Select Control unit 09 (Central Electrics) Control unit Long Coding Byte 17 Bit2-Bit3 Activate. 聽 Quote Lock Acknowlegde with Horn Horn When Locked Select Control unit 09 (Central Electrics) Control unit Long Coding Byte 5 Bit 1 Activate Horn When UnLocked Select Control unit 09 (Central Electrics) Control unit Long Coding Byte 5 Bit 4 Activate 聽 Quote Controlling in MMI Menu Select Control unit 09 (Central Electrics) Control unit Long Coding Byte 5 Bit 2 De-Activate Activation of Audi Parking System Select Control unit 10 (parking aid) Control unit access authorization - Select function 16 Access Code 71679 Control unit coding -> Se莽im function 07 Byte 0 Bit 2-3 (08 visual display active (BAP NEW) selection) Adaptation Select "Visual display for park assist" New Value: OPS Display Shot Down Warning Tone for Parking System Select Control unit 10 (parking aid 2) Adaptation Select "Park Assist activation tone" New Value:off (default: on) Park Assist Activation Speed Limit Select Control unit 10 (parking aid 2) Adaptation Select "Switch-off speed of parking assist" New Value: Choose value between 0 km/h - 20 km/h (default: 10 km/h) MMI Music Sound Reduction with the Parking System Select Control unit 10 (parking aid 2) Adaptation Select "Audio reduction request" New Value:on (default: off) Parking System Varning Tone Frequency-Front Select Control unit 10 (parking aid 2) Adaptation Select "Speaker frequency for the front Park Assist" Select Value Between "Stage 1- Stage 9" Parking System Varning Tone Frequency-Rear Select Control unit 10 (parking aid 2) Adaptation Select "Speaker frequency for the rear Park Assist" Select Value Between "Stage 1- Stage 9" Start/Stop Activation-Deactivation on FIS Select Control unit 17 (Dashboard) Adaptation Warning light for Start / Stop Value to "off" position (default: on) Seat Belt Warning Select Control unit 17 (Dashboard) Adaptation Select "Deactivate seat belt warning" New Value "yes" (Default: no) Hill Hold Assist Activation Select Control unit 03 (brake / ABS) Control unit coding Byte 16 and Bit 0 Activate Adaptation Select Berganfahrhilfe Adjustment: 0 = Berganfahrhilfe "Normal" 1 = Berganfahrhilfe "Early" 2 = Berganfahrhilfe "Late" Pointer Test Select Control unit 17 (Dashboard) Adaptation Select Channel "Staging" New Value:Active Adjust Consumption Ind谋cator Select Control unit 17 (Dashboard) Adaptation Customize consumption indicator Basic De臒eri 100 Value change 85 (%) and 115 (%) . Enable Mirror Heating Select Control unit 52 (T眉relektr. Beifahr.) Control unit Long Coding Byte 04 Bit 0 Deactivate Select Control unit 42 (T眉relektr. Driver) Control unit Long Coding Byte 04 Bit 0 Deactivate Folding Mirror when Doors Lock Select Control unit 42 (door Electrical driver) Control unit Long Coding Byte 4 Bit 6 Activate Control unit 52 (door Electrical front passenger) Control unit Long Coding Byte 4 Bit 6 Activate Activation of Headlight Wash Select Control unit 09 (Central Electrics) Control unit Long Coding Byte 20 Bit 5 DeActivate Rain Lighting Select Control unit 09 (Central Electrics) Control unit Long Coding Subsystem: Select RLS (rain and light sensor) Byte 0 Bit 1 DeActivate Activation of Tire Pressure System Select Control unit 03 (ABS / brake control unit) Control unit Long Coding Byte 16 Bit 1 Activate Emergency Break/Flashing Lights Select Control unit 09 (Central Electrics) Control unit Long Coding Byte 16 Bit 1 Activate Bit 2 Activate Enable-Disable DLR on MMI Select Control unit 09 (Central Electrics) Control unit Long Coding Byte 15 Bit 7 Activate-This is a hidden bit. You have to direct edit. Disable DRL with Hand Break Select Control unit 09 (Central Electrics) Control unit Long Coding Byte 11 Bit 0 Activate-This is a hidden bit. You have to direct edit.
