Hi guys and please welcome me into the Audi community. Hello to everyone 😂
I’ve got a slight issue with an Audi a4 2.0 tdi with engine code CAG year 2010
now this is what has happened
drove the car fine no problems at all then turned it off went shopping came back out and wouldn’t start so had the AA come out and have a look and said the fuel pump in the tank isn’t pumping any diesel so fast forward a couple of days, we fitting another pump in the tank which is pumping out fuel but the car still won’t start, we’ve also replaced the fuel filters and got fuel up to the HPFP
heres the things I’ve currently checked
fuel getting to HPFP
theres no filling in the HPFP
no check engine light
ive got fuel to the injectors
i used a duty meter for the injectors when cranking and got 8.3% duty
checked the throttle flap wasn’t stuck shut
is there anything else I should be looking at?
I do really appreciate any help on this one
Thanks in advance
camshaft or crank sensor  be iffy  bud
I’ve just got the vcds on it and when cranking here’s the readings
Crank position sensor reading 224rpm
cam sensor reading 107 rpm
would this look correct?
thanks
Welcome to the forum you'll find the members on here are a friendly and helpful bunch 🙂
Not sure what the figures should be for the cam or crank sensors. Another thought isn't there a fuel pump module? Could this be at fault?
Thanks in advance
hi,do you have an update on this please hope you got sorted. thanks
Very good question Stephen.
Regrettably, our homeland original poster, hasn’t returned to the  forum since the day he first joined. Will we ever know?
Hi yes it appeared to have 2 failed injectors which didn’t bring up any codes on the vcds.
bought 2 injectors which supposedly were tested and good but 1 was faulty, the car runs now but has a slightly misfire and still smells but thinking of driving the car to see if the ecu learn the driving characteristics and sorts itself out
do you have a similar issue? Maybe I can help
Hi Gareth I may not of returned due to being busy with work but I will reply to any messages and help when I can, if you are ever stuck on a problem please feel free to message
many thanks 👍
  • Like 2
