Seamus7 Posted April 4, 2023 Share Posted April 4, 2023 I have a 2012 Audi A4 2.0Diesel CJCB engine. Occasionally, not always (annoyingly), it goes into Limp Mode under heavy acceleration. The fault code persistently stored is Fuel Rail pressure too low.. and there was also one occasion where the fault listed was P106500 - Fuel regulation discrepancy. I will post a recent full VCDS log below: Here is a list of attempted fixes for this issue; -replaced fuel tank pump -replaced pressure regulator valve -replaced fuel high pressure sensor -replaced inlet metering valve -replaced common rail -replaced diesel filter -and of course a full service of the car When the P106500 DTC came up recently I searched and found many people online that were experiencing similar difficulties with Limp Mode, all with varying solutions like, it needed injectors, it needed a pressure regulator valve &, it needed the "Nox-fix" software update. I was hoping someone might be able to more efficiently direct us to the problem than just throwing more parts at it like Audi wanted to. Thanks. Also, I notice during Advanced Measuring Block analysis of injection deviation in the 4 cylinders, that injector 1 & 3 are usually ranging from +0.4-+3.0, whereas injector2&4 are always negative values. This leads me to suspect the injectors, as the inj1&3 deviation sometimes grows more positive while driving, with the car unable to accelerate full throttle. This is often most usually when the car is cold. Sorry about the very long explanation but I wanted to be as precise as possible. Code: Tuesday,04,April,2023,15:55:17:36501 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64 VCDS Version: 23.3.0.0 (x64) HEX-V2 CB: 0.4631.4 Data version: 20230228 DS346.1 www.Ross-Tech.com VIN: WAUZZZ8K2DA037376 License Plate: Chassis Type: 8K-AU48 (8R0) Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72 VIN: WAUZZZ8K2DA037376 Mileage: 329860km-204965miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CJCB) Labels:. 03L-906-018-CGL.clb Part No SW: 03L 906 018 JP HW: 03L 906 018 JL Component: R4 2.0l TDI H25 9978 Revision: 45H25--- CVN: 38A39BC7 Coding: 0A194012242401080000 Shop #: WSC 80093 222 69422 ASAM Dataset: EV_ECM20TDI01103L906018JP 003007 ROD: EV_ECM20TDI01103L906018AC.rod VCID: 015F8852E181E35200D-8054 VINID: 9D196AAAA21B0944400C70C71885A05E15 2 Faults Found: 5211 - Fuel Rail/System Pressure P0087 00 [096] - Too Low Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 8 Mileage: 329428 km Date: 2023.03.27 Time: 16:07:54 Engine RPM: 2209.50 /min Normed load value: 98.4 % Vehicle speed: 107 km/h Coolant temperature: 80 °C Intake air temperature: 19 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 14.780 V Unlearning counter according OBD: 39 Fuel temperature: 29.6 °C Mean injection quantity: 60.44 mg/stroke Rail pressure regulation: status-Bits 0-7: 5 Fuel high-pressure: actual value: 1245300 hPa High fuel pressure: specified value: 1432100 hPa Pressure control valve adaptation factor: 1.0901 Fuel level: 20.00 l 5582 - Oil Pressure Switch for reduced Oil Pressure P164D 00 [032] - Malfunction Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 329805 km Date: 2023.04.03 Time: 00:00:29 Engine RPM: 831.00 /min Normed load value: 22.7 % Vehicle speed: 0 km/h Coolant temperature: 91 °C Intake air temperature: 13 °C Ambient air pressure: 1020 mbar Voltage terminal 30: 14.560 V Unlearning counter according OBD: 38 Fuel consumption: 0.66 l/h Engine oil temperature: 97.2 °C Oil warning threshold: 43.596 mm Status of oil pressure switches-Bits 0-7: 0 Oil fill level: 67.096 mm Outside temperature: 8.5 °C Fuel temperature: 28.0 °C Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 CG HW: 8K0 907 379 CG Component: ESP8 front H09 0100 Revision: -------- Serial number: -------------- Coding: 161544 Shop #: WSC 06324 000 00000 VCID: 00598D56EA0BEA5A0F3-8054 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 FB HW: 8K0 907 064 FB Component: BCM2 2.0 H10 0602 Revision: 00002001 Coding: 03B10000000000000000 Shop #: WSC 06325 000 00000 VCID: 75B7EC82A5C9DFF22C5-8020 Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H60 0072 Serial number: 0512000019641010 Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E Component: J764 ELV MLB H40 0046 Serial number: 2312000040648015 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb Part No SW: 8K2 820 043 AC HW: 8K2 820 043 AC Component: KLIMA 3 ZONEN H04 0123 Revision: D0000000 Serial number: 01130320121485 Coding: 342402E000 Shop #: WSC 06325 000 00000 VCID: 6A8DCFFEFC77000AB17-803E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 DC HW: 8K0 907 063 AC Component: BCM1 1.0 H14 0103 Revision: 03014001 Serial number: 00000392624102 Coding: 290000B08034A7C00081000000001F1F001D020827080201000008000000020000000024000000 Shop #: WSC 00899 210 89304 VCID: 73B3D29AABBDC1C2021-8026 Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB Component: WWS 120312 H06 0070 Serial number: SWF12030125219 Coding: 00FD11 Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0002 Serial number: 20196703 Coding: 02005D Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS Component: E1 - LDS H03 0031 Serial number: 00000000000803120600 Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H02 0002 Serial number: 5A088C16000000000001 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8K0-959-655.clb Part No SW: 8K0 959 655 N HW: 8K0 959 655 N Component: AirbagVW-AU10 H45 0610 Serial number: 003KFD91R428 Dataset Number: 8K0909602Q 0001 Coding: 30534435363030303030554A3052384B3053 Shop #: WSC 53484 001 1048576 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 48C95576823B121A873-801C Crash sensor for side airbag: driver side: Serial number: 6334MSME6B5160204 Front Passenger's Side Airbag Crash Sensor: Serial number: 6344MSME6B540D69S Rear Side Airbag Crash Sensor (on driver's side): Serial number: 6352QSME2D113366C Passenger side rear thorax airbag crash sensor: Serial number: 6362QSME700F3068H Crash sensor for front airbag: driver side: Serial number: 63732SME09103F5C1 Crash sensor for front airbag: front passenger side: Serial number: 63832SME436C1F6CG No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8R0 953 568 S HW: 8R0 953 568 S Component: Lenks.Modul H07 0171 Revision: 00000000 Serial number: 20210915000003 Coding: 000016 Shop #: WSC 05398 394 139842 VCID: 51FF781271E1D3D2D0D-8004 Component: E221 - MFL H03 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 982 B HW: 8K0 920 982 B Component: KOMBIINSTR. H35 0540 Revision: 00000000 Serial number: NTE46J43D Coding: 3304080002012600010000 Shop #: WSC 06325 000 00000 VCID: 3333129AEB3D81C2C21-8066 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8R0 907 468 C HW: 8R0 907 468 C Component: GW-BEM 4CAN-M H10 0025 Revision: 1Y030014 Serial number: 1441Y12303006B Coding: 00CF07FF00 Shop #: WSC 06325 000 00000 VCID: 3FDB4EAAD77555A2369-806A Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181 Component: J367-BDMHella H03 8041 Serial number: 6244976901 Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663 Component: J532_DCDCStab H17 0042 Serial number: 12068000116011200181 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8T0 959 793 F HW: 8T0 959 793 H Component: TSG FA H09 0302 Revision: -------- Serial number: -------------- Coding: 011002204001410001 Shop #: WSC 06325 000 00000 VCID: 4CC1696696C3FE3AA3B-8018 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb Part No SW: 8K0 909 144 F HW: 8K0 909 144 B Component: RCEPS H36 0507 Revision: 00001000 Serial number: 0002414348 Dataset Number: 8K0909852H 0023 Coding: 100000000001 Shop #: WSC 21177 000 1048576 ASAM Dataset: EV_RCEPSAU48X 008014 ROD: EV_RCEPSAU48X_008.rod VCID: 34311186EEB386FADBB-8060 2 Faults Found: 2305 - Function Restriction due to Start Voltage Interruption U1410 00 [008] - - [Funktionseinschränkung der Lenkung durch Spannungseinbruch bei niedriger Geschwindigkeit] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 229 Mileage: 327860 km Date: 2023.03.06 Time: 21:24:26 Write only channel 2306 - Function Restriction due to Start Voltage Interruption U1410 00 [008] - - [Funktionseinschränkung der Lenkung durch Spannungseinbruch bei hoher Geschwindigkeit] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 4 Reset counter: 11 Mileage: 329589 km Date: 2023.03.31 Time: 17:17:56 Write only channel ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 FB HW: 8K0 907 064 FB Component: BCM2 2.0 H10 0602 Revision: 00002001 Serial number: 0172273070 Coding: 011B062200B900408020013680000000 Shop #: WSC 06325 000 00000 VCID: 75B7EC82A5C9DFF22C5-8020 Subsystem 1 - Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8T0 959 792 H HW: 8T0 959 792 H Component: TSG BF H08 0302 Revision: -------- Serial number: -------------- Coding: 011002204001410001 Shop #: WSC 06325 000 00000 VCID: 4DC764626DD9F732B45-8018 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb Part No SW: 8K0 907 801 J HW: 8K0 907 801 J Component: EPB-4 H01 0001 Revision: -------- Serial number: 10000000026029 ASAM Dataset: EV_ParkiBrake 001022 ROD: EV_ParkiBrake_AU48.rod VCID: 36352B8EF8CF94EAE5F-8062 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb Part No SW: 4G0 035 056 D HW: 4G0 035 056 Component: Radio U STD H60 0094 Revision: AB001007 Serial number: 229C$0C7570583 Coding: 010003020100000001 Shop #: WSC 06325 000 00000 VCID: 221DE7DE44C7184A397-8076 1 Fault Found: 02984 - Connection between Impedance Converter 2 and Window Antenna 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 6 Reset counter: 11 Mileage: 329767 km Time Indication: 0 Date: 2023.04.02 Time: 22:35:26 Freeze Frame: Voltage: 14.80 V ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 8R2 035 652 A HW: 8R2 035 652 Component: B-BN-EU H62 0175 Revision: -------- Serial number: 147CW0C7507613 Coding: 01010100000681ED01800B4E000000030000 Shop #: WSC 06325 000 00000 VCID: 323D179E142788CAC97-8066 Subsystem 1 - Part No: 4G0 919 884 K Component: EUR 2012 1308 Subsystem 2 - Part No SW: 8T0 919 604 HW: 8T0 919 604 Component: DU6 Basic H42 0098 Serial number: 9465C 0C2517648 Subsystem 3 - Part No SW: 8T0 919 611 HW: 8T0 919 611 Component: E0380 Bedient H01 0100 Serial number: 00000001095309 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb Part No SW: 8T0 959 795 H HW: 8T0 959 795 H Component: TSG HL H07 0302 Revision: -------- Serial number: -------------- Coding: 010002204001210001 Shop #: WSC 06325 000 00000 VCID: 50F97D167AEBDADADF3-8004 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb Part No SW: 8T0 959 795 H HW: 8T0 959 795 H Component: TSG HR H07 0302 Revision: -------- Serial number: -------------- Coding: 010002204001210001 Shop #: WSC 06325 000 00000 VCID: 50F97D167AEBDADADF3-8004 No fault code found. End----------(Elapsed Time: 01:33, VBatt start/end: 12.1V/12.1V)----------- Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted April 4, 2023 Share Posted April 4, 2023 2 hours ago, Seamus7 said: I have a 2012 Audi A4 2.0Diesel CJCB engine. Occasionally, not always (annoyingly), it goes into Limp Mode under heavy acceleration. The fault code persistently stored is Fuel Rail pressure too low.. and there was also one occasion where the fault listed was P106500 - Fuel regulation discrepancy. I will post a recent full VCDS log below: Here is a list of attempted fixes for this issue; -replaced fuel tank pump -replaced pressure regulator valve -replaced fuel high pressure sensor -replaced inlet metering valve -replaced common rail -replaced diesel filter -and of course a full service of the car When the P106500 DTC came up recently I searched and found many people online that were experiencing similar difficulties with Limp Mode, all with varying solutions like, it needed injectors, it needed a pressure regulator valve &, it needed the "Nox-fix" software update. I was hoping someone might be able to more efficiently direct us to the problem than just throwing more parts at it like Audi wanted to. Thanks. Also, I notice during Advanced Measuring Block analysis of injection deviation in the 4 cylinders, that injector 1 & 3 are usually ranging from +0.4-+3.0, whereas injector2&4 are always negative values. This leads me to suspect the injectors, as the inj1&3 deviation sometimes grows more positive while driving, with the car unable to accelerate full throttle. This is often most usually when the car is cold. Sorry about the very long explanation but I wanted to be as precise as possible. Code: Tuesday,04,April,2023,15:55:17:36501 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64 VCDS Version: 23.3.0.0 (x64) HEX-V2 CB: 0.4631.4 Data version: 20230228 DS346.1 www.Ross-Tech.com VIN: WAUZZZ8K2DA037376 License Plate: Chassis Type: 8K-AU48 (8R0) Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72 VIN: WAUZZZ8K2DA037376 Mileage: 329860km-204965miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CJCB) Labels:. 03L-906-018-CGL.clb Part No SW: 03L 906 018 JP HW: 03L 906 018 JL Component: R4 2.0l TDI H25 9978 Revision: 45H25--- CVN: 38A39BC7 Coding: 0A194012242401080000 Shop #: WSC 80093 222 69422 ASAM Dataset: EV_ECM20TDI01103L906018JP 003007 ROD: EV_ECM20TDI01103L906018AC.rod VCID: 015F8852E181E35200D-8054 VINID: 9D196AAAA21B0944400C70C71885A05E15 2 Faults Found: 5211 - Fuel Rail/System Pressure P0087 00 [096] - Too Low Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 8 Mileage: 329428 km Date: 2023.03.27 Time: 16:07:54 Engine RPM: 2209.50 /min Normed load value: 98.4 % Vehicle speed: 107 km/h Coolant temperature: 80 °C Intake air temperature: 19 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 14.780 V Unlearning counter according OBD: 39 Fuel temperature: 29.6 °C Mean injection quantity: 60.44 mg/stroke Rail pressure regulation: status-Bits 0-7: 5 Fuel high-pressure: actual value: 1245300 hPa High fuel pressure: specified value: 1432100 hPa Pressure control valve adaptation factor: 1.0901 Fuel level: 20.00 l 5582 - Oil Pressure Switch for reduced Oil Pressure P164D 00 [032] - Malfunction Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 329805 km Date: 2023.04.03 Time: 00:00:29 Engine RPM: 831.00 /min Normed load value: 22.7 % Vehicle speed: 0 km/h Coolant temperature: 91 °C Intake air temperature: 13 °C Ambient air pressure: 1020 mbar Voltage terminal 30: 14.560 V Unlearning counter according OBD: 38 Fuel consumption: 0.66 l/h Engine oil temperature: 97.2 °C Oil warning threshold: 43.596 mm Status of oil pressure switches-Bits 0-7: 0 Oil fill level: 67.096 mm Outside temperature: 8.5 °C Fuel temperature: 28.0 °C Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 CG HW: 8K0 907 379 CG Component: ESP8 front H09 0100 Revision: -------- Serial number: -------------- Coding: 161544 Shop #: WSC 06324 000 00000 VCID: 00598D56EA0BEA5A0F3-8054 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 FB HW: 8K0 907 064 FB Component: BCM2 2.0 H10 0602 Revision: 00002001 Coding: 03B10000000000000000 Shop #: WSC 06325 000 00000 VCID: 75B7EC82A5C9DFF22C5-8020 Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H60 0072 Serial number: 0512000019641010 Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E Component: J764 ELV MLB H40 0046 Serial number: 2312000040648015 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb Part No SW: 8K2 820 043 AC HW: 8K2 820 043 AC Component: KLIMA 3 ZONEN H04 0123 Revision: D0000000 Serial number: 01130320121485 Coding: 342402E000 Shop #: WSC 06325 000 00000 VCID: 6A8DCFFEFC77000AB17-803E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 DC HW: 8K0 907 063 AC Component: BCM1 1.0 H14 0103 Revision: 03014001 Serial number: 00000392624102 Coding: 290000B08034A7C00081000000001F1F001D020827080201000008000000020000000024000000 Shop #: WSC 00899 210 89304 VCID: 73B3D29AABBDC1C2021-8026 Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB Component: WWS 120312 H06 0070 Serial number: SWF12030125219 Coding: 00FD11 Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0002 Serial number: 20196703 Coding: 02005D Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS Component: E1 - LDS H03 0031 Serial number: 00000000000803120600 Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H02 0002 Serial number: 5A088C16000000000001 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8K0-959-655.clb Part No SW: 8K0 959 655 N HW: 8K0 959 655 N Component: AirbagVW-AU10 H45 0610 Serial number: 003KFD91R428 Dataset Number: 8K0909602Q 0001 Coding: 30534435363030303030554A3052384B3053 Shop #: WSC 53484 001 1048576 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 48C95576823B121A873-801C Crash sensor for side airbag: driver side: Serial number: 6334MSME6B5160204 Front Passenger's Side Airbag Crash Sensor: Serial number: 6344MSME6B540D69S Rear Side Airbag Crash Sensor (on driver's side): Serial number: 6352QSME2D113366C Passenger side rear thorax airbag crash sensor: Serial number: 6362QSME700F3068H Crash sensor for front airbag: driver side: Serial number: 63732SME09103F5C1 Crash sensor for front airbag: front passenger side: Serial number: 63832SME436C1F6CG No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8R0 953 568 S HW: 8R0 953 568 S Component: Lenks.Modul H07 0171 Revision: 00000000 Serial number: 20210915000003 Coding: 000016 Shop #: WSC 05398 394 139842 VCID: 51FF781271E1D3D2D0D-8004 Component: E221 - MFL H03 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 982 B HW: 8K0 920 982 B Component: KOMBIINSTR. H35 0540 Revision: 00000000 Serial number: NTE46J43D Coding: 3304080002012600010000 Shop #: WSC 06325 000 00000 VCID: 3333129AEB3D81C2C21-8066 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8R0 907 468 C HW: 8R0 907 468 C Component: GW-BEM 4CAN-M H10 0025 Revision: 1Y030014 Serial number: 1441Y12303006B Coding: 00CF07FF00 Shop #: WSC 06325 000 00000 VCID: 3FDB4EAAD77555A2369-806A Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181 Component: J367-BDMHella H03 8041 Serial number: 6244976901 Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663 Component: J532_DCDCStab H17 0042 Serial number: 12068000116011200181 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8T0 959 793 F HW: 8T0 959 793 H Component: TSG FA H09 0302 Revision: -------- Serial number: -------------- Coding: 011002204001410001 Shop #: WSC 06325 000 00000 VCID: 4CC1696696C3FE3AA3B-8018 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb Part No SW: 8K0 909 144 F HW: 8K0 909 144 B Component: RCEPS H36 0507 Revision: 00001000 Serial number: 0002414348 Dataset Number: 8K0909852H 0023 Coding: 100000000001 Shop #: WSC 21177 000 1048576 ASAM Dataset: EV_RCEPSAU48X 008014 ROD: EV_RCEPSAU48X_008.rod VCID: 34311186EEB386FADBB-8060 2 Faults Found: 2305 - Function Restriction due to Start Voltage Interruption U1410 00 [008] - - [Funktionseinschränkung der Lenkung durch Spannungseinbruch bei niedriger Geschwindigkeit] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Reset counter: 229 Mileage: 327860 km Date: 2023.03.06 Time: 21:24:26 Write only channel 2306 - Function Restriction due to Start Voltage Interruption U1410 00 [008] - - [Funktionseinschränkung der Lenkung durch Spannungseinbruch bei hoher Geschwindigkeit] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 4 Reset counter: 11 Mileage: 329589 km Date: 2023.03.31 Time: 17:17:56 Write only channel ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 FB HW: 8K0 907 064 FB Component: BCM2 2.0 H10 0602 Revision: 00002001 Serial number: 0172273070 Coding: 011B062200B900408020013680000000 Shop #: WSC 06325 000 00000 VCID: 75B7EC82A5C9DFF22C5-8020 Subsystem 1 - Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8T0 959 792 H HW: 8T0 959 792 H Component: TSG BF H08 0302 Revision: -------- Serial number: -------------- Coding: 011002204001410001 Shop #: WSC 06325 000 00000 VCID: 4DC764626DD9F732B45-8018 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb Part No SW: 8K0 907 801 J HW: 8K0 907 801 J Component: EPB-4 H01 0001 Revision: -------- Serial number: 10000000026029 ASAM Dataset: EV_ParkiBrake 001022 ROD: EV_ParkiBrake_AU48.rod VCID: 36352B8EF8CF94EAE5F-8062 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb Part No SW: 4G0 035 056 D HW: 4G0 035 056 Component: Radio U STD H60 0094 Revision: AB001007 Serial number: 229C$0C7570583 Coding: 010003020100000001 Shop #: WSC 06325 000 00000 VCID: 221DE7DE44C7184A397-8076 1 Fault Found: 02984 - Connection between Impedance Converter 2 and Window Antenna 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 6 Reset counter: 11 Mileage: 329767 km Time Indication: 0 Date: 2023.04.02 Time: 22:35:26 Freeze Frame: Voltage: 14.80 V ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 8R2 035 652 A HW: 8R2 035 652 Component: B-BN-EU H62 0175 Revision: -------- Serial number: 147CW0C7507613 Coding: 01010100000681ED01800B4E000000030000 Shop #: WSC 06325 000 00000 VCID: 323D179E142788CAC97-8066 Subsystem 1 - Part No: 4G0 919 884 K Component: EUR 2012 1308 Subsystem 2 - Part No SW: 8T0 919 604 HW: 8T0 919 604 Component: DU6 Basic H42 0098 Serial number: 9465C 0C2517648 Subsystem 3 - Part No SW: 8T0 919 611 HW: 8T0 919 611 Component: E0380 Bedient H01 0100 Serial number: 00000001095309 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb Part No SW: 8T0 959 795 H HW: 8T0 959 795 H Component: TSG HL H07 0302 Revision: -------- Serial number: -------------- Coding: 010002204001210001 Shop #: WSC 06325 000 00000 VCID: 50F97D167AEBDADADF3-8004 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb Part No SW: 8T0 959 795 H HW: 8T0 959 795 H Component: TSG HR H07 0302 Revision: -------- Serial number: -------------- Coding: 010002204001210001 Shop #: WSC 06325 000 00000 VCID: 50F97D167AEBDADADF3-8004 No fault code found. End----------(Elapsed Time: 01:33, VBatt start/end: 12.1V/12.1V)----------- Hi sounds like you are on the right track with the injectors but before you throw money at them have a leak back test done as that should tell you definitively, did a Skoda recently that was loosing 30ml of fuel in 40 seconds thats where the fuel pressure was going, you have replaced everything that normally causes your symptoms, normal leak back should be about 3ml a minute. Steve. Quote Link to comment Share on other sites More sharing options...
