Alan Dobson Posted April 22, 2023 Posted April 22, 2023 oil pump failed so I've had a replacement engine (not a 170BHP), although the diesel injectors from the 170BHP have been used. the car starts up and will tick over quite happily, but when taken out for a run it initially goes very well but then the engine cuts out. there are no faults shown on the ODB2 read out. everything we can think of has been changed or checked i.e. the injectors, the fuel pump, but the fault continues. does anyone have any ideas as to what the fault may be?
Steve Q Posted April 22, 2023 Posted April 22, 2023 Has the engine been coded to the ECU etc as I'm wondering if it could be an imobiliser issue?
