Hello Essy,
Could be an ABS sensor ( or sender) , but diagnostics should point you to the offending one - or whatever is the issue.
15 hours ago, cliffcoggin said:
What do you mean by "changing gear strangely"?
Holds in gear to long before changing up like as if it was in sport mode but its not…
The possibilities are almost endless. ABS system, ECM, faulty gear selector switch, defective battery, wrong wheel/tyre sizes for example. You should get the car diagnosed by a decent code reader.
  • 4 months later...
