Hi. Right Turn repeater in Door mirror wont work when turning, but it flashes when I unlock, the car it don't flash when I lock the car, but will flash when I unlock it. If I relock without opening the door it will flash. I know it's a bit confusing but can anyone tell me what fuse to check. Thank You.
  • 2 months later...
It may be not fuse problem, anyway you should check F36 fuse inside interior fuse box (interior fuse box location) try to replace it even if it looks good. If it wont help, go for VCDS  diagnostic.
Audi-A3-S3-8V-2012-2013-interior-fuse-bo
