nigel mooring Posted May 11, 2023 Posted May 11, 2023 High I had a High Pressure Fuel Pump Fail and Blocked Injectors. I have unblocked injectors, cleaned and renewed all lines filters etc but the car still will not fire up, does my Fuel Pump need coding to the car or is there something I have missed ?
Steve Q Posted May 11, 2023 Posted May 11, 2023 Is it a new pump or second hand one? Either way if it's not the original pump then it'll need coding. If it's anything like my older A6 the injection pump is linked in with the imobiliser so needs a professional
nigel mooring Posted May 12, 2023 Author Posted May 12, 2023 16 hours ago, Steve Q said: Is it a new pump or second hand one? Either way if it's not the original pump then it'll need coding. If it's anything like my older A6 the injection pump is linked in with the imobiliser so needs a professional Thank you Steve, I have a chance to borrow a coding machine and saw a video a while ago how to do this so will give it a try first
