mkrbeck Posted May 14, 2023 Posted May 14, 2023 My son recently brought a 1.6i 8P. "Dad the steering whines a bit when parking is that a problem ?" "Nah probably needs some fluid. Ah wheres the fluid reservoir then ??" So i have googled & found out its electric power steering, & its not uncommon to have problem with such. It whines sometimes maneuvering but he says its ok driving normally. My question to the no-doubt resident A3 guru's on this forum, and owners who have experienced this, what is the likely prognosis for such, whats the detailed cause here, could the electric steering soldier on for years with a bit of whine when maneuvering at slow speeds, or is it a known problem that is likely to get worse over time ? thnks Martyn
Magnet Posted May 15, 2023 Posted May 15, 2023 Hello Martyn, Thanks for joining and being in touch. Apologies for asking questions, but is the situation worse following morning start ups, or is the severity much the same under all usage conditions? Kind regards, Gareth.
mkrbeck Posted May 15, 2023 Author Posted May 15, 2023 Hello Gareth asked my son - its not any worse in the mornings than at any other time. And he tells me it is intermittent. All thoughts welcome thnks
Magnet Posted May 15, 2023 Posted May 15, 2023 Daft as it may sound, but battery is worth eliminating before moving on to more complex causes. Kind regards, Gareth.
Magnet Posted May 16, 2023 Posted May 16, 2023 Hello Martyn, You would need to get it check via. a reasonably professional test - say at Halfords - rather then just with a DIY multimeter. Kind regards, Gareth.m
