Bizarney Posted June 9, 2023 Posted June 9, 2023 My 3ltr tdi sport 2016 model has a fault on the navigation system.I have performed a reboot on the mmi and all systems have initialised including the nav. However after a few minutes the map dissapears and a message comes up “ data not enabled “ the the nav does not work. any help would be much appreciated.
Steve Q Posted June 9, 2023 Posted June 9, 2023 I'd recommend a diagnostic check to see if any fault codes flag up
Bizarney Posted June 9, 2023 Author Posted June 9, 2023 Thanks for the reply Steve. I have a fault reader so will try in the morning and let you know the result. Any idea where the port is located on my car ?
Steve Q Posted June 10, 2023 Posted June 10, 2023 Either behind the ash tray or under the dash I think. Driverside
