C_logue Posted June 11, 2023 Posted June 11, 2023 Having a rattle/possible blown door speaker in my a7 sline ultra, it has the standard speaker set up but was interested in replacing with the black edition Bose or other after market door speakers. Any recommendations or guidance would be much appreciated thanks.
Steve Q Posted June 12, 2023 Posted June 12, 2023 Bose speakers should be able to be sourced very easily via eBay. If you're going the whole hog and fitting the amp and sub you might find the amp might need coding.
C_logue Posted June 12, 2023 Author Posted June 12, 2023 25 minutes ago, Steve Q said: Bose speakers should be able to be sourced very easily via eBay. If you're going the whole hog and fitting the amp and sub you might find the amp might need coding. Don’t think I’ll go the whole hog, just the door speakers to give a bit better sound, cheers Steve
