allanjolly Posted June 13, 2023 Posted June 13, 2023 Hi can i change rear brake pads with electronic parking brake with the engine running to release parking brake, would this allow me to push piston back
Stevey Y Posted June 13, 2023 Posted June 13, 2023 9 hours ago, allanjolly said: Hi can i change rear brake pads with electronic parking brake with the engine running to release parking brake, would this allow me to push piston back Hi, NO you need to put the car in to service lining mode with VCDS/OBD and make sure you have a battery connected to the jump posts under the bonnet otherwise if your battery is as old as the car and the voltage drops it will fry the calliper motors. Steve.
