Marcin_78 Posted June 25, 2023 Posted June 25, 2023 Hi everyone. I've just join the club 😊. Can anyone tell me if 17" alloy wheels will fit my Audi A6 C7? I've got currently 18" wheels. I want to fit my winter tyres 215.50.17. Any ideas? Thanks.
Steve Q Posted June 27, 2023 Posted June 27, 2023 I think winter wheels are 17" as is the space saver I believe so you should be fine.
Solution Magnet Posted June 27, 2023 Solution Posted June 27, 2023 Hello Marcin, The overall diameter of the wheel plus tyre must come into this equation, so if you are fitting small diameter wheels, then the tyre profile must increase ( for the same wheel width). The object is is to retain the same overall diameter. There should be online calculators that will check compatibility for you. Kind regards, Gareth.
Marcin_78 Posted June 27, 2023 Author Posted June 27, 2023 7 hours ago, Steve Q said: I think winter wheels are 17" as is the space saver I believe so you should be fine. Thank you Steve.
Magnet Posted June 27, 2023 Posted June 27, 2023 Any comments on my points Marcin? Kind regards, Gareth.
Marcin_78 Posted June 27, 2023 Author Posted June 27, 2023 18 minutes ago, Magnet said: Any comments on my points Marcin? Kind regards, Gareth. Hi Gareth. Yes, you are right. I've spoken with my mechanic and he said the same thing. Thank you for your help. 👍 1
