Hi There,
I recently viewed an A5 convertible that needs a few things. Amongst these when I viewed were 2 noticeable wear marks that happened in the same place around 2 inches from the rear window. It's annoying as the rest of the roof is basically spot on. I have added some photos. It's only the canvas and I'm not convinced it's even through to the rubber shell. Does anybody know if you can spot/patch repair areas and does anybody have any experience of this.? Is it a common fail place and would anybody know why it's done it.?. Your help would be much appreciated.
Many Thanks
Mario
Hello Mario,
Sorry, I don’t have any experience of common wear spots on this hood, but the general wear line appears to be in a fold where the fabric will rest when the roof is down. I would expect the wear holes to be where there is some sort of bracket or similar has been in contact with it, again when it’s folded down.
Repair? To me, I can only see this being done with a patch. Where would you get material to be anything like the now faded hood, even if you like the idea of a patch?
It could be me, but the hood material seems rather open texture, and I wonder if it has been given a good couple of blasts with a pressure washer.
It's a sign it'll be needing a new fabric roof soon. Not cheap to change at all.
  • 9 months later...
On 7/2/2023 at 12:37 PM, Mario T said:
Hi There,
Many Thanks
Mario
