Hi all
A6 (c6) 3lt allroad.
Hi has anyone upgraded or no of any possible upgrades to the air intake system. There seems to be a lot of plastic taking up a lot of room. Or is it just best leave it be.
Thanks Grant.
  On 7/7/2023 at 3:54 PM, grim said:
Hi all
Thanks Grant.
Expand
Hi there are a world of aftermarket alleged upgrades most will cause some sort of problem weak mixture/ overfuel during cold weather etc, if you look at the manufacturers point of view why spend loads of money developing a system that works when you could use cheaper cone filters and silicone pipework and spend more on wide band sensors to  cope with  the fluctuations of that system.
I know on the A6 c5 induction kits etc are pointless and the stock airbox is actually best. You.might.be better going for an.upgraded panel filter from k&n ect. As heat soak will be your biggest issue with induction kits.
