Aaaa7 Posted July 15, 2023 Posted July 15, 2023 Hi I have the following code displayed (P17D400) along with the message ‘gearbox malfunction you may continue driving’ which happens on occasion. I’ve researched this and obviously the DSG’s are a mine field, however I’m hoping the fact I can list the issues below may help identify further: - it can take a second or two to select gear D1 and if on a hill it will judder pulling away - If it can’t select D1 it goes to D2 with the ‘malfunction message and won’t change up or down from D2 - reverse is a similar story and won’t always select all the above issues are temporarily resolved by turning the car on and off again, it is worth noting that If it’s taking a second or so to select D1 and I apply some accelerator then it sometimes engages quite violently and lurches forward and then all good and continues up through the gears and I can travel 100’s of miles with no issue, it’s only that R and D1. anyone with some knowledge or similar experiences I’d be grateful for a reply and I’ll be sure to keep this updated with developments. I’ve read about solenoids potentially causing this or could a clutch pack be more likely? Thanks in advance
Steve Q Posted July 15, 2023 Posted July 15, 2023 Solenoids can be a problem or the module. However the first thing I'd look at is when was the gearbox oil last changed? Degrading/old oil can affect the gearbox to change gears effectively. 1
Aaaa7 Posted July 15, 2023 Author Posted July 15, 2023 (edited) Hi thanks for the reply. The gearbox oil was changed when the problem started as a first port of call, I also tried the reset (hold the accelerator down for 30 secs etc) Are the solenoids independent from the mechatronic unit or built within them? Is it better to replace the mechatronic unit or do the new units not come with the new solenoids? Thanks again for any help 👍 Edited July 15, 2023 by Aaaa7
Aaaa7 Posted July 15, 2023 Author Posted July 15, 2023 Also if anyone would know if the clutch pressure solenoids N439 and N435 are part of the mechatronic unit or seperate? Apologies, my knowledge on this isn’t great but I’m thinking clutch pressure solenoids first followed by mechatronic unit replacement if not and also a check of the common cable I’ve read about that leaks from the coolant in to the gearbox selector or ecu.
ricardodm Posted February 25 Posted February 25 Hey... I am having the same problem.... What is the solution? Have you figured out?
ricardodm Posted February 25 Posted February 25 On 7/15/2023 at 2:59 PM, Aaaa7 said: Also if anyone would know if the clutch pressure solenoids N439 and N435 are part of the mechatronic unit or seperate? Apologies, my knowledge on this isn’t great but I’m thinking clutch pressure solenoids first followed by mechatronic unit replacement if not and also a check of the common cable I’ve read about that leaks from the coolant in to the gearbox selector or ecu. Any update?
cliffcoggin Posted February 25 Posted February 25 Ricardo. The OP has not looked at the forum for a year and a half so you will not get a reply. Please start a topic of your own. I am locking this topic.
