Astech101 Posted July 20, 2023 Posted July 20, 2023 I've recently bought a 1995 2.6E in decent condition but with lots of little things that need addressing. However, I can't find any information on whether the following was standard: Electric or manual aerial? Lights on buzzer? Should it have clear or orange front indicator lens'? Should it have a factory alarm fitted? Is it activated with a fob or on the central locking? Cheers! Matt.
audia4b5kev Posted July 20, 2023 Posted July 20, 2023 https://www.google.com/search?q=1995+2.6e+cabriolet+specs&sxsrf=AB5stBgwtdebT9r7KKFhJ0P1Qh_dUr9rkg%3A1689872903037&ei=B2q5ZLTgAbuX9u8P_76AoAs&oq=1995+2.6E+Cabriolet+SPEC&gs_lp=Egxnd3Mtd2l6LXNlcnAaAhgCIhgxOTk1IDIuNkUgQ2FicmlvbGV0IFNQRUMqAggAMgQQIRgVSI80UKggWKggcAJ4AJABAJgBgwKgAYMCqgEDMi0xuAEByAEA-AEBwgILEAAYogQYsAMYiwPiAwQYASBBiAYBkAYC&sclient=gws-wiz-serp 1
Astech101 Posted July 20, 2023 Author Posted July 20, 2023 Checked the first 5 result and none of them answer my questions
Magnet Posted July 21, 2023 Posted July 21, 2023 Hello Matt, Have you searched EBay for a copy of the sales brochure for your model year. That should tell you all standard and optional equipment. Kind regards, Gareth. 1
Steve Q Posted July 22, 2023 Posted July 22, 2023 If it has an alarm I suspect the siren will be in the boot side panel. Electric aerial was standard I think as was the headlights on function. Even my old ford escort has that. If you have a sticker in your boot it might have the different codes on it which would highlight the spec when codes are put in a decoder. Think clear lenses were fitted to facelift cars if I'm not mistaken
coupe4 Posted July 29, 2023 Posted July 29, 2023 yes steve it would have the clear lenses in 1995 and also the alarm shoucd activate when the key is used to lock the car[no fob],it works off a vacuum pump/motor and its located on thedrivers side behind the panel youd call a door card if it had a door.hope this helps,greg.
