New to Audi and this forum. I have just bought an A4 B8 Avant 2014 teknik. Has 17" alloys on. But bought some 18" rotors. And you know the score. They don't fit! 66.6mm hub and 57.1mm wheel centres! What have you lot done to get fer round this!?? Spacers obvious solution, but what size spacers? Don't want then sticking out! 7.5J et54, hubs stick out about 15mm. So guessing 15mm at the minimum. Thanks in advance,聽
i personaly dont know the answer lee, but welcome to the forum from a fellow yorkshire man馃憤馃榿
Thank you. 馃憤
1 hour ago, JMKC82 said:
Hi thanks for your reply. My hub on the car.聽 The bit that is in the centre of the disc that protrudes, has the bearing in it. It's 66.6mm diameter. The alloy wheel centre. That fits over it. Is 57.1mm diameter. Too small to go over it so won't fit the car. Hope that is clearer.聽
