Itspointless Posted July 28, 2023 Share Posted July 28, 2023 Hi thanks for looking. After rebuilding my engine there's a rattle coming from the front of the engine! Does it sound like the chain? I'm thinking maybe I might need to re tension it? Whats the thoughts on this please ? 20230728_141343.mp4 Thanks. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted July 28, 2023 Share Posted July 28, 2023 I've struggled to hear the specific noise. But it could be a chain or tensioner causing rattling. Quote Link to comment Share on other sites More sharing options...
Itspointless Posted July 29, 2023 Author Share Posted July 29, 2023 Yeah it's the loud rattling sort of noise you can hear over everything. When I start it from cold it's pretty much silent but as it gets warmer the noise gets louder. I'm gonna reset the tension today, hopefully it solves it. Thanks. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted July 29, 2023 Share Posted July 29, 2023 Fingers crossed it solves the problem 🙂 please keep us posted on how you get on Quote Link to comment Share on other sites More sharing options...
Itspointless Posted July 29, 2023 Author Share Posted July 29, 2023 Well I've reset the tensioner, and as I released the plunger it's gone back to where it was before. I've checked all the timing marks are aligned which they are. A friend said if the timing was out it would throw up a code anyway. Maybe this dephaser pulley is faulty, but id imagine it would throw a code for that if it was? It's strange that once the engine is warm (oil thiner) it starts to make the noise. I think I'm gonna throw some castrol in it or something. Thanks. Quote Link to comment Share on other sites More sharing options...
Itspointless Posted July 29, 2023 Author Share Posted July 29, 2023 I've just read another timing procedure instructions online that says to tension the chain with the camshaft support bracket removed. And the instructions a friend printed for me says to tension the chain with the support in place. Maybe this is where I have gone wrong? Thanks. Quote Link to comment Share on other sites More sharing options...
Itspointless Posted July 29, 2023 Author Share Posted July 29, 2023 Well I've tensioned the chain with the bracket removed put it back together and it's still the same. Definitely sounds like it's coming from the inlet cam pulley. Guess I'm gonna have to strip down the top end again and replace the camshaft. Quote Link to comment Share on other sites More sharing options...
Itspointless Posted August 15, 2023 Author Share Posted August 15, 2023 Update on this. Inlet camshaft pulley buggered! Quote Link to comment Share on other sites More sharing options...
Steve Q Posted August 15, 2023 Share Posted August 15, 2023 3 hours ago, Itspointless said: Update on this. Inlet camshaft pulley buggered! Glad you found the cause. But Why'd it happen? Quote Link to comment Share on other sites More sharing options...
Itspointless Posted August 15, 2023 Author Share Posted August 15, 2023 52 minutes ago, Steve Q said: Glad you found the cause. But Why'd it happen? I have no idea, it was new but a pattern part. The pulley has a few mm play and knocks when I twist it left or right. Replaced with a OEM shaft and it's fine now. The pattern part has INA stamped on it but so does the audi one. About £400 price difference though. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted August 17, 2023 Share Posted August 17, 2023 Wowzers. But could have been a lot more costly I guess. Quote Link to comment Share on other sites More sharing options...
