grimzz Posted August 5, 2023 Share Posted August 5, 2023 hi all i seem to have an intermittent right inner brake light issue it will flag up as a fault when its raining when dry it seems to work most of the time had the guys at work take a look they think possible pcb issue and think i should get a replacement tried looking seem in short supply any ideas anyone come across this issue ? thank you . Quote Link to comment Share on other sites More sharing options...
Steve Q Posted August 5, 2023 Share Posted August 5, 2023 Have you checked to see if the rear lights fill with water? Have all the connections been checked for corrosion Quote Link to comment Share on other sites More sharing options...
grimzz Posted August 5, 2023 Author Share Posted August 5, 2023 4 hours ago, Steve Q said: Have you checked to see if the rear lights fill with water? Have all the connections been checked for corrosion Hi yes no water im wondering about using a glue gun on the pcb connection and resealing the unit ? Quote Link to comment Share on other sites More sharing options...
Steve Q Posted August 6, 2023 Share Posted August 6, 2023 On 8/5/2023 at 7:37 PM, grimzz said: Hi yes no water im wondering about using a glue gun on the pcb connection and resealing the unit ? Worth a shot Quote Link to comment Share on other sites More sharing options...
Solution grimzz Posted September 4, 2023 Author Solution Share Posted September 4, 2023 Found a direct replacment on eBay all fitted working lovely . Quote Link to comment Share on other sites More sharing options...
Steve Q Posted September 5, 2023 Share Posted September 5, 2023 Glad you got sorted 🙂 Quote Link to comment Share on other sites More sharing options...
