I have an Audi A4 Avant 1.4 TFSI 2017. Is it possible to replace the Air Conditioning Control Unit with another from a standard A4? The units look identical, is it as simple as plug and play? Thanks.
Hi think the unit will have to be re coded to the car unless its the same part number as the old unit.
Thanks for the response. So if I got the exact same part number, it should be fine?
