Godwin1985 Posted August 16, 2023 Posted August 16, 2023 I have an Audi A4 Avant 1.4 TFSI 2017. Is it possible to replace the Air Conditioning Control Unit with another from a standard A4? The units look identical, is it as simple as plug and play? Thanks.
Stevey Y Posted August 16, 2023 Posted August 16, 2023 On 8/16/2023 at 11:56 AM, Godwin1985 said: I have an Audi A4 Avant 1.4 TFSI 2017. Is it possible to replace the Air Conditioning Control Unit with another from a standard A4? The units look identical, is it as simple as plug and play? Thanks. Expand Hi think the unit will have to be re coded to the car unless its the same part number as the old unit. Steve.
Godwin1985 Posted August 16, 2023 Author Posted August 16, 2023 Thanks for the response. So if I got the exact same part number, it should be fine?
