Jeaningo Posted August 17, 2023 Share Posted August 17, 2023 Hello Folks Im looking for a new used A6 I found an Audi A6 2.7 sline manual le mans estate is that a Quattro or front/rear wheel drive ? Another point is manual I'm not sure is that the right option I assume is not recommend to go for a manual !? Cheers jean Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted August 17, 2023 Share Posted August 17, 2023 1 hour ago, Jeaningo said: Hello Folks Im looking for a new used A6 I found an Audi A6 2.7 sline manual le mans estate is that a Quattro or front/rear wheel drive ? Another point is manual I'm not sure is that the right option I assume is not recommend to go for a manual !? Cheers jean Hi they only did front wheel drive/Quattro, if it is a Quattro it will have a badge to that effect on the tailgate other than that look underneath for a prop shaft which goes to the rear Haldex unit it will also have driveshafts on the rear, why not if its manual, in my considered opinion the manual box is better and you get far less problems than the power robbing auto units. Steve. Quote Link to comment Share on other sites More sharing options...
