AlanEss Posted August 18, 2023 Posted August 18, 2023 My a4 has started throwing too lean error Has got worse over time, now getting dead patches as I accelerate until turbo cuts in. Has anyone an idea what to check for?
Steve Q Posted August 18, 2023 Posted August 18, 2023 Is it worth you checking the maf, lambda sensor and coil packs/spark plugs first.
AlanEss Posted August 24, 2023 Author Posted August 24, 2023 I have done the suggested checks and cleaned the MAF with contact cleaner. Now runs more smoothly but still showing same error. This happens miles after the engine reaches operating temperature. I haven't found any leaking air pipes so far. Is there anything that is temperature sensitive?
Steve Q Posted August 24, 2023 Posted August 24, 2023 Could there be an issue with leaking boost pipes?
A4 Clueless Posted June 10, 2024 Posted June 10, 2024 I have just started getting the same issue with my 2007 cabriolet. I installed a new MAF and the engine still “pulses” on cold idle and throws up the running lean issue. Exhaust starts popping and there is a “thud” sound from the air intake. However, if i unplug the MAF, the car idles perfect and the pulsing, thuds and pops disappear???? At the moment I am running the car without the MAF plugged in until i can figure out why it doesn't work with a new MAF installed. Would be interested to see how yours runs if you unplugged the MAF? Following this tread to hopefully find some answers.
