hello all,my airbag light came on last weekend on my 1995 audi coupe,the vcds is saying its the airbag igniter on the passenger side ,i tried clearing it but it keeps coming back.is this the cylinder type unit attached to the seat belt assembly and can it be replaced?ive never seen this come up as a fault before.thanks greg.
Hello Gregg,
Always worth giving the under-seat connectors a good dose of contact cleaner - and a good wiggle - before doing anything else.
Beware ( in caps) do not remove or violently wiggle any of the connectors.
hi gareth thanks for replying.mine being the 95 model it has no wiring under the seats.theres a wire going to the seatbelt assembly/roller so i might disconnect that and give it a clean,ill post any progress i make[if any!]thanks greg
Hello Gregg,
DO NOT DISCONNECT anything without first leaving the battery disconnected for half an hour.
thanks gareth,ive the battery off since saturday anyway so ill go at it this evening.greg
