Cant get any gear in.....  Worked perfect until i should reverse out of garage. No noise, can start engine in neutral,  difficult to get key out, must put in P and press hard on gearshifter. No oilleak.
If auto even was the gearbox last serviced?
Is the selector eliminated?
It could be the gearbox module.
I'd also recommend a diagnostic check to see if any fault codes flag up
are you pressing on brake pedal to to get out gear or in gear  ?  kev
