Jon king Posted August 26, 2023 Posted August 26, 2023 Hi, I have a 2007 AUDI A6 TDI QUATTRO and the fuel gauge doesn’t work, after start up it pings up the orange petrol pump symbol then saying refuel even after me putting fifty pounds in.........and ideals would be great, thanks
Steve Q Posted August 26, 2023 Posted August 26, 2023 It could either be the level sensor or a fault with the instrument cluster. The latter could be more expensive
Stevey Y Posted August 26, 2023 Posted August 26, 2023 6 hours ago, Jon king said: Hi, I have a 2007 AUDI A6 TDI QUATTRO and the fuel gauge doesn’t work, after start up it pings up the orange petrol pump symbol then saying refuel even after me putting fifty pounds in.........and ideals would be great, thanks Hi it could be the level sensor as Steve said these are attached to the lift pump in the rear under the rear seat I believe and are prone to getting perforated or the level sensor itself is faulty, try taking the pump out and lifting the float manually to see if the light goes out, if not it is because the graduation unit [electrical] has given up the ghost in which case it all comes as one unit. Steve.
Jon king Posted August 27, 2023 Author Posted August 27, 2023 Steve and Steve, Many thanks for replying will address both ideas and see how we go, Many thanks Jon
Jon king Posted August 28, 2023 Author Posted August 28, 2023 Most definitely will, Many thanks for your valuable info.....Jon
