jijo Posted August 31, 2023 Share Posted August 31, 2023 Have just replaced the camshaft and crankshaft sensor on audi a4 2.0tdi s-line. Also just replaced the timing belt. The car won't start now, no error codes are coming up. Battery full but coming on dash that it's low. Any help appreciated thanks Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted August 31, 2023 Share Posted August 31, 2023 7 hours ago, jijo said: Have just replaced the camshaft and crankshaft sensor on audi a4 2.0tdi s-line. Also just replaced the timing belt. The car won't start now, no error codes are coming up. Battery full but coming on dash that it's low. Any help appreciated thanks Hi re check the cam belt timing or did it run fine after the belt was changed and only play up after the sensor change. Steve. Quote Link to comment Share on other sites More sharing options...
jijo Posted August 31, 2023 Author Share Posted August 31, 2023 20 minutes ago, Stevey Y said: Hi re check the cam belt timing or did it run fine after the belt was changed and only play up after the sensor change. Steve. Was working fine before, only changed as had the console off and looked a bit frayed when changing the sensor Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted September 3, 2023 Share Posted September 3, 2023 On 8/31/2023 at 6:57 PM, jijo said: Was working fine before, only changed as had the console off and looked a bit frayed when changing the sensor Hi its possible that you have a dodgy sensor, not unknown, I have pulled them out of a new box and fitted them and had the same result, avoid NAPA or any of the own brand stuff on eBay you can't go wrong with a bit of FEBI/HELLA/BOSCH they might be a bit dearer but when fitted you will see where the extra money went. Steve. Quote Link to comment Share on other sites More sharing options...
jijo Posted September 4, 2023 Author Share Posted September 4, 2023 14 hours ago, Stevey Y said: Hi its possible that you have a dodgy sensor, not unknown, I have pulled them out of a new box and fitted them and had the same result, avoid NAPA or any of the own brand stuff on eBay you can't go wrong with a bit of FEBI/HELLA/BOSCH they might be a bit dearer but when fitted you will see where the extra money went. Steve. Hi Steve, all part's fitted have come from audi. Would rather pay bit extra like u say 1 Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted September 4, 2023 Share Posted September 4, 2023 7 hours ago, jijo said: Hi Steve, all part's fitted have come from audi. Would rather pay bit extra like u say Hi it is still possible its a wrong un try fitting the old one and see what happens if its the same you could have a wiring problem at the plug on the main loom where it connects to the sensor. Steve. Quote Link to comment Share on other sites More sharing options...
