Q7 Brake servo restricted start/stop system fault function u
Pappa583
Anybody had these messages pop up, start stop warning goes off when I disable the start stop by pressing the button in dashboard and the brake servo warning comes in then goes off? It's a 2016
Edited by Pappa583
Year
Hi I would start by replacing the valve on the front of the servo about ten mins work there is a massive post about these units on the forum under BAKE SERVO RESTRICTED other than that it could be a battery problem.
Cheers, found the post and ordered the sensor. Looks pretty straightforward to swap out
