H11KUC Posted September 7, 2023 Posted September 7, 2023 (edited) Hello Audi Owners, So, I thought I'd put up this post for those who, like me, are having a bit of a nightmare with their Audi A6 C7 gearbox shifting. I've been scouring the web, but couldn't find any decent fixes. Lots of people posted about it, but most just ended up taking their cars to the dealer, and there were no updates after that. I got this car about 6 months ago, and at first, I didn't notice the issue. The issue was that the gear shifting felt pretty bumpy when moving from 1st to 2nd gear, especially when stuck in slow-moving traffic. However, if you put your foot down and accelerate a bit more aggressively, it shifted smoothly. That's the easiest way to put it. So, I decided to get to the bottom of it. I started with a gearbox service, changing the oils in both the gearbox and mechatronic, along with the mechatronic filter. No luck, didn't make a difference. Then I turned my attention to the suspension, swapping out the arms. Nope, that didn't help either. I heard a weird noise coming from the CV joint on one side and decided to change the entire driveshaft. Still, no improvement. I was getting ready to tackle the clutch when I dropped by the local garage, and they suggested taking a look at the dual mass flywheel (DMF) because they heard some noise when starting the car. Finally, after swapping out the DMF, the car shifts like a dream now. I'm not saying this is the silver bullet for all shifting problems, but I hope it helps someone out there identify or relate to their issue. To describe my issue better, the scanner didn't show any errors, the car used to jerk from 1st to 2nd with a loud banging noise from underneath. Also, when downshifting from 3rd to 2nd and from 2nd to 1st, it would make the same noise and jolt. When driving faster, I noticed a slight power drop when shifting into 4th and 6th gear, meaning the car didn't accelerate smoothly through the gears during acceleration. Good luck fixing it if you are having the same problem. Edited September 7, 2023 by H11KUC 1
cliffcoggin Posted September 29, 2024 Posted September 29, 2024 16 hours ago, Paul1975 said: I have the same problem That's unfortunate, but DMF faults are well known and expensive. What are you going to do about it?
Paul1975 Posted September 29, 2024 Posted September 29, 2024 I am going to replace the DMF mine is in the very early stages So going to nurse it till the newyear then get it sorted
DanVAG Posted October 21, 2024 Posted October 21, 2024 Hi original poster I have a S4 with the same 7 speed dsg box and it has a DMF noise when idling and I'm wondering if you ever had any thuds when upshifting through the gears?
H11KUC Posted October 21, 2024 Author Posted October 21, 2024 46 minutes ago, DanVAG said: Hi original poster I have a S4 with the same 7 speed dsg box and it has a DMF noise when idling and I'm wondering if you ever had any thuds when upshifting through the gears? Hi Dan, I'm not entirely sure if the gearboxes are completely identical. The code for mine is 0CK 301. Anyway, it was shifting roughly at low speeds, particularly between 1st and 2nd gear. Occasionally, I could also feel a slight jolt between 3rd and 4th gear. Just to add, I didn’t notice any noise from the DMF while idling, only when starting the car. Hope you manage to get it sorted. Nik
