hafizur Posted September 8, 2023 Posted September 8, 2023 (edited) Hi everyone Car: Audi A3 8P 2009 2.0T FSI Sportback Quattro Car cranks by won't start, it seems its lacking fuel or something along them lines VCDS scan shows the following 001089 - EVAP Emission Control Sys P0441 - 000 - Incorrect Flow - Intermittent - MIL ON 008854 - Fuel Pressure Regulator Valve (N276) P2296 - 000 - Short to Plus - Intermittent I checked the voltage on the connector for the sensor ( i think its the correct sensor, see photo), it is showing as 1.2v with ignition on first turn Unable to check what voltage I get when trying to start Have a new EVAP valve ready to collect but don't think that is causing the issue of not starting as it started for a while with the EVAP issue Any advice would be appreciated Edited September 8, 2023 by hafizur
hafizur Posted September 8, 2023 Author Posted September 8, 2023 Tested the connector, getting 2volts when cranking Also getting fuel coming out of the hose on the bottom I am assuming its either that pump or injectors further down the line
